Fan is oscillating - display dead
Ventilation is going into boost modus and going back to standard, making lots of noise.
I don’t seem to be able to get in the menu, display shows a half bar.
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
Hi,
It sounds like the logic board has failed. The spinning up could be the humidity sensor or it could be the faulty logic boards.
Some systems have a wired controller if this is the issue then you can check the screen on the unit itself. In this case a new remote controller can be added. It would be interesting to know what the issue was as I appreciate you asked this question a while ago.
Hope this helps,
Tom.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 237
