Ir para o conteúdo principal
Repair guides and support for 17" laptops in the Pavilion Notebook 17 series. These laptops have model numbers 17-g000 – 17-g099.
16 Perguntas Visualizar todos
Laptop doesn’t boot makes clicking sound and then repeats
Laptop makes a click or spark sound around the CMOS battery area
17 inch HP Pavilion with i5 4th gen processor
Recently replaced my HDD to an SSD and when I went to test out the SSD I accidentally picked up the laptop to turn it around and forgot about the rechargeable battery which immediately turned off the computer.
I tried rebooting the computer again and it just turns on all lights with fan running and then few seconds later turns off and hearing a click sound that happens when you hard power it off (holding down the power button) and then repeats
What I tried already was resetting the power multiple times and also connecting with only AC adapter to no avail.
Esta é uma boa pergunta?
Pontuação 0
4 comentários
James Chen exactly what happened when you "forgot about the rechargeable battery" and turned your laptop over?
por
@oldturkey03 what I mean by that was when I picked up the laptop to turn it around the rechargeable battery came out of its battery contact pins and the computer completely turned off
por
Yes, that is what I thought. Have you checked the connectors/cables and traces to make sure that nothing came loose or got pulled off?
por
Yes I have took each and every cable out and re connected them.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
well this happened to my old computer and was told that i fried the board while trying to replace my hdd
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
James Chen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 559
