Ir para o conteúdo principal
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
20 Perguntas Visualizar todos
Why wont my camera take a picture
so i just got my camera recently when the film got stuck, so i pulled it out and then the lights on the lens started flashing so i replaced the batteries but its still flashing can someone please help me
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
My camera gos on but it wont take a picture and the front ceps fkasing until i turn it off. I have tried changing batteries. Im panicking rn ps help🦋💞
por
Adicionar um comentário
1 resposta
This instax camera only work with alkaline batteries and do not use any batteries other than alkaline batteries. Make sure you have used the correct ones.
Note that if you replace the batteries while the lens is retracted, the lights will continue to blink.
If only the red lamp comes on, simply turn the camera off by pushing the lens back into the body and replace the batteries. Provided that the camera isn’t damaged, this should do the trick.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lili Mirza será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 207
