Ir para o conteúdo principal
Lenovo Essential G560. This laptop has a 15.6" screen, along with a full keyboard with number pad.
On upgrading the RAM windows just dies
My Laptop supports max frequency of 8500 Mhz but I later I realized that I have installed a 10600S (2GB DDR3) in it and its working but its not sufficient for Windows 10. Its an old laptop and I think of using it as a server.
So I took a 4 GB DDR3 with 12800S (1600 Mhz) from my other laptop and installed in it, it POSTed fine but Windows is crashing. So I want to buy a RAM (1333 Mhz) but I don't know if it will work or not. The Samsung 1333 Mhz RAM stick is cheaper and 1066 Mhz Stick is costly, I know they run at lower frequency but will they run?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
When upgrading memory, it’s always safest to use brand/speed/type of RAM recommended on the motherboard’s manufacturer’s website. In a pinch, you can try the instructions provided in the following link (included in the instructions is a link to buy the correct RAM from Amazon):
Lenovo Essential G560 RAM Replacement and install 4gb RAM
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sourabh Thakur será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 93
