Ir para o conteúdo principal
Motorola Moto 360 2nd Gen Smart Watch manufactured by Motorola Mobility in 2015. Wearable Smartwatch that connects to your phone.
Battery Replacement 6 pin spanner
Doing a battery replacement for the Moto 360 2nd Gen and I’m stuck at the part which requires me to remove the button. Is the 6/3 pin spanner sold anywhere? Is there a replacement that I can get?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
part number: IF145-373-51
description: iFixit Precision 4 mm Screwdriver Bit / Spanner 6.0
cost (as of today) $2.99
Make sure you select ‘Spanner 6.0’ before adding to cart! The drop-down has all available bits in it.
Imagem de iFixit Precision 4 mm screwdriver bits. Replacement bits for the Pro Tech Toolkit, Mako Driver Kit, and Manta Driver Kit.
Produto
$2.99
Esta resposta foi útil?
Pontuação 0
2 comentários:
This tool is nothing to do with removing the button on a 2nd gen moto 360. So this is both annoying and misleading
por
I'm sorry, I found this to be the closest thing to help me remove the button. Is there a better way or better tool?
por
Adicionar a sua resposta
Dacheng Li será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 345
