Ir para o conteúdo principal
The Maxima was redesigned for the 2009 model year and made its debut at the 2008 New York International Auto Show.
What is causing my car to not go
I have a 08 Nissan Maxima and I have replace the alternator then replace the radiator an put two sencor in and I was ony way home from work and it felt like the engine blew but I know it didn't and now it's making a awful noise likes it from the front of engine please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Dont drive car when metal to metal sounds are happening! Need more details like was car overheating was serpentine belt still in tact etc radiator and alternator repairs are signs your car has high mileage so make sure all bolts were tightened and all fluids are topped off like coolant engine oil and transmission fluid. Tow car home or to shop if possible then try to start the vehicle if it starts let it idle and look and listen for source of the loud sounds you heard and trouble shoot each symptom.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Renea carmen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Ao todo: 148
