Ir para o conteúdo principal
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Directional pad not working
A few days ago my little brother spilt milk on my remote and the d-pad quit working. I took it apart and cleaned it and got the d- pad to work in the up and right direction but it still won't work in the left or down direction is there a way to fix this.?
P.s. Also when I shake the controller it sounds like theres something it the controller moving around like a a bunch of small prices but when I take it apart there's nothing.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
I would not suggest you to take apart the controller if you have no knowledge about repairing things on your own. Take it to the store and see if they can find the problem if not, buy a new one. Most of the time when there is liquid damaged, things will stop working properly and most of the time they are not able to be saved.
Cheers!
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks man and I know what I'm doing. I've replaced parts on controllers be for.
por
My D-pad was not working properly so I dropped drops of alcohol and other cleaners to fix the issue and at the beginning it worked but then It started failing again so I did it again and this time the left direction is dead. I sent it to be repaired and they told it couldn't be salvaged yet they repaired the thumbsticks just to force me to pay them
por
Adicionar a sua resposta
Michael Cox será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 2,444
