Ir para o conteúdo principal
Released in 1996 by Nintendo, second device in the Game Boy line
17 Perguntas Visualizar todos
Can something fix my gameboy pocket's battery compartment?
My gameboy pocket has had battery corrosion completely destroy it, is there anyway to replace or fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Forbz 20 it will depend on what the situation looks like. Post some pictures of the damaged compartment etc with your question. that way we can see what you see. Adicionar imagens a uma pergunta já existente
Yo want to clean the compartment with some vinegar and cotton tipped applicators. See if there is a chance to replace the copper contacts or if you can go to something different. It should be a doable repair. If you can’t you may have to try to find a rear panel replacement
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Forbz 20 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 161
