Ir para o conteúdo principal
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
How to fix keyboard keys on a chromebook C202?
Some of my chromebook C202 keyboard keys won't work after I press them. For example, the back space, h key and esc and others.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Aaron,
If you know how to dismantle the keyboard, open up ... clean up the keyboard from dust and use an eraser to rub on the contacts of the LVDS cable... reinsert and try again.
take caution on the delicate plastic locking mechanism locking the lvds cable of the keyboard module.
If you had tried and it does not work still,
There is a possibility that the keyboard internal circuitry path is faulty.
It is a common issues for laptops actually.
internal track wearing off…..
If your laptop is still under warranty, send it for service or consider replacing the whole keyboard module which i think is a better solution which you can try sourcing the replacement parts at amazon, ebay, aliexpress, etc.
https://www.amazon.com/KBR-Replacement-C...
Esta resposta foi útil?
Pontuação 2
Related Parts and Tools
Adicionar a sua resposta
Aaron Hagos será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 829
