Ir para o conteúdo principal
Released May 2012, identified by model number J2011-03-US.
LED Flashing red when plugged in.
When charging my Big Jambox the LED ring around the power button is pulsing red. It says 3/4 battery when I press the “J” button and is still connects to my bluetooth. I cannot understand if this is a problem or not I don’t remember it flashing red before.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Your battery is failing! While it still may offer enough for the amount you are using the speaker the battery will need replacing soon.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thank you!
Any suggestions for a good replacement battery? I've found several on Amazon just not sure what I should be looking for.
por
Here's the guide to replace it Jawbone Big Jambox Battery Replacement As to who's battery I don't have any option on who's
por
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 76
Ao todo: 8,408
