Ir para o conteúdo principal
The Lenovo G50-80 is an entry level personal laptop released by Lenovo in 2009. The laptop has a 15.6 in screen and uses an Intel GPU processor.
OneKey Recovery/ HDD upgrade to SSD
Hi, I had this laptop for almost 3 years now and I have been looking for an upgrade I got a 480gb SSD I copied all my data from the old HDD to the SSD using a software but once I replaced them and tried to boot the OneKey recovery would pop up and non of the opinion initial backup nor the user backup work.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
What was the size of the original drive. I don’t recommend this software. You should have bought [produto vinculado ausente ou desativado: IF107-131] and used this https://www.macrium.com/reflectfree . I never had issues with macrium.
Esta resposta foi útil?
Pontuação 0
11 comentários:
The original drive is a 1TB HDD, and I did use the macrium reflect 7 for copying the data I wanted to use the SSD as a boot drive and the HDD as external I already have hard drive enclosure with USB 3.0
por
The only problem I get is with the OneKey Recovery I searched online and couldn’t find a way of bypassing it or disabling it
por
I think not all your files fitted in. You should have bought bigger drive. How much free space did the original have?
por
About 600GB was free
por
After transferring all my files there was about 70GB free left on the SSD
por
Exibir mais 6 comentários
Adicionar a sua resposta
Nedzhati será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 1,419
