Ir para o conteúdo principal
4.0 megapixel point and shoot digital camera by Canon.
Constant Memory Card Error
I keep getting “Memory Card Error” no matter how many cards I try. Can it be fixed? Thanks
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Are you able format it?
por
Adicionar um comentário
1 resposta
Solução escolhida
If you are formating the cards on PC, are you using FAT32 or exFAT (or NTFS?)? You should format your card to FAT32.
Esta resposta foi útil?
Pontuação 2
4 comentários:
Thank you so much for your help. I was formatting at the incorrect settings. Thanks again. Best news I have received in a long, long time.
Irving E. Carlson
Owner
Carlson Studios
por
por
Can someone please explain "formatting a card on PC"? I just got a new memory card from Amazon and "memory Card Error" appears with old and this new card"Tab on side is in up position. Sheila, Senior Citizen. Thank you.
por
Thank you for share with us.
por
Adicionar a sua resposta
Irving Carlson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 325
