Ir para o conteúdo principal
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
How to disable shortcuts?
I’m trying to disable the command-comma shortcut which opens finder preferences for whatever application i’m using. I want to disable it. I’ve already tried going to system preferences > keyboard> and i couldn’t find the shortcut to edit, but found plenty of others.
How do i disable the command-comma shortcut?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
The shortcut should be in the Keyboard Control Panel in the tab settings Shortcuts clicking on the Keyboard section. If it is not in there it might not be disable-able
Esta resposta foi útil?
Pontuação 1
1 comentário:
not disable-able-able?
extremely lame considering the up and down arrow keys have a knowable manufacturer malfunction.
por
Adicionar a sua resposta
Andrew será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 82
