Ir para o conteúdo principal
The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
20 Perguntas Visualizar todos
Toshiba Chromebook 2 will not run on battery power.
Toshiba Chromebook 2 will not run on battery power even though the battery indicates fully charged.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
First how old is the computer? Do you keep it plugged in all the time? The battery could be ran down or have a bad cell. I would start off by replacing the battery with a new one, or barrow one from someone that will work on just the battery swap out the batteries and see if it will then. Most likely the battery will need to be replaced.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Gene será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 65
