Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
20 Perguntas Visualizar todos
Touch ID makes screen swipe up and down after screen replacement.
I just replaced the screen and it was working fine, but i kept opening up the phone to try and fix a problem with the proximity sensor, but now I have a new problem. Watch the video.
Also, can anyone help me with the proximity sensor? I can’t get the screen to turn off when I put it up against my face. I’ve already scraped out some of the circle so that there’s no chance of it being to dark.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
It looks like it could be a bad screen/scanner. You may have to buy a new one. It is very unlikely but possible it is a software issue that requires a reset. I would back it up the reset it, an if that doesn't work, then I would install a different screen and scanner
Esta resposta foi útil?
Pontuação 1
Hi Benjamin,
I just replaced the earpiece on my iPhone 7 and everything is working fine except for the exact same problem you have.
When Touch ID is required and I touch the sensor the screen starts to jump up and down. When trying to add a new fingerprint I noticed that the finger is not recognized.
Could you solve the problem?
Pontuação 0
Adicionar a sua resposta
Benjamin Gabriel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 745
