Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1199 Perguntas Visualizar todos
Why won't my iPhone turn on?
Hey everyone, I just bought an iphone on ebay, and it doesnt turn on. The internals are 100% fine, it just has no signs on life with a brand new screen I just put on it. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
I have iphone x , while playing pubg it turns off automatically , now it is not turning on and not showing tha apple logo after force reset..
por
Same exact problem tried fixing using itunes still the pc don't recognize my phone
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Can you get it to connect to a computer?
Hold down the power button. (i know) It may seem a bit rude to ask that. But i know some people that have forgot to hold down the power button before.
Try tilting the charger a bit while plugged in to make sure it has a good connective current.
If that doesn’t work, this is a great troubleshooting guide.
Esta resposta foi útil?
Pontuação 1
19 comentários:
I held it down, and tilted it, still nothing.
por
I also connected to computer and it didnt work
por
The phone is probably saying (if its there at all) "Do you want to trust this device?" So let me do some research and I will list some other ideas.
por
On an iPhone 8 or later: Press and quickly release the Volume Up button. Press and quickly release the Volume Down button. Then press and hold the Side button until you see the Apple logo.
Website: https://support.apple.com/en-us/HT201412
por
ive tried plugging it into a display too
por
Exibir mais 14 comentários
Check your LDI indicators to see if your device is liquid damaged. They are little white bars that turn red in contact with a liquid.
Pontuação 0
2 comentários:
there is no liquid damage
por
Have you checked if your battery is good with a multi-meter?
por
Veja o conteúdo da imagem:
Pontuação 0
never buy a used phone that dosent turn on. especially iphones, because most likely even if you get it to power on the old owners apple id (icloud account) will still be logged in. and if thats the case the phone is a paperweight to anyone but the original owner. i would just open an ebay return and be done with it.
Pontuação 0
Adicionar a sua resposta
Philip Doherty será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 5,474
