Ir para o conteúdo principal
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
Is the RAM upgradeable?
Is it possible to upgrade the RAM to 4GB, if you have the 2GB version?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The RAM is integrated into the logic board. Upgradable only from the factory. It can be in 2 GB and 4 GB models.
Esta resposta foi útil?
Pontuação 4
Sadly numerous workstations have fixed bottoms or memory that is bound onto the motherboard, the two circumstances which keep you from redesign the RAM. It's likewise conceivable that the framework can't perceive in excess of a specific measure of memory and you could as of now be at the maximum
Pontuação 1
Adicionar a sua resposta
Lee Strobel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 708
