Ir para o conteúdo principal
Repair guides and support for motherboards and CPUs.
ASUS H110M-D Can't find IDE mode in BIOS.
Hi Guys!, I just want to ask if Asus H110M-D Mother Board supported the IDE mode in the Bios.
thanks for the help guys!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
If you need to configure or set up your computer motherboard’s CMOS, BIOS, or chipset, see the Motherboard CMOS Configuration and Setup page for instructions.
I believe the setting you want is to set “SATA Mode” to “AHCI.”
Esta resposta foi útil?
Pontuação 1
2 comentários:
Yes how to do it? because there is no setting in BIOS of IDE and AHCI only SATA.
por
It took some digging, but this is what I found:
Because the Intel H110 chipset only supports AHCI mode, there might not be an additional option about SATA mode under BIOS.
por
Adicionar a sua resposta
Joebert Lazano será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 3,821
