Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
3 Beeps after installing RAM
I purchased 2x 4GB PC3-L 12800s DDR3 1600MHz and installed both sticks, got 3 beeps when trying to boot. I removed 1 new stick and installed old 1GB stick and Mac booted up just fine.
I then found out that these were the wrong RAM for my mac and so I removed the new RAM and bought and installed 2x 4GB PC3-8500 DDR3 1066MHz and got the 3 beeps again. I removed one and installed the old 1GB stick, and got the 3 beeps again. I tried every combination using the new and old or the new only and still getting the 3 beeps.
Help please!!
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Is the beep pattern identified on this list?
https://support.apple.com/en-us/HT202768
por
Is the 'old' setup not working anymore ?
por
Adicionar um comentário
2 respostas
Solução escolhida
Exactly which machine do you have? Please go here and input your serial number from the back of your machine in very fine print:
https://everymac.com/ultimate-mac-lookup...
UPDATE
Thanks for giving us your exact machine.
Install the original RAM. Zap the PRAM
Here's how to reset your PRAM:
  • Shut down your machine. Yes, all the way down, not sleep or logging out.
  • Press the power button and then press command-option-p-r. ...
  • Hold those keys down until your Mac reboots again and you here the startup chime.
  • Let go of the keys and let your Mac reboot normally.
  • If this works, install one of the new chips and boot, then do the next one.
Esta resposta foi útil?
Pontuação 3
6 comentários:
MacBook Pro "Core 2 Duo" 2.26 13" (SD/FW) 2.26 GHz Core 2 Duo (P7550*)
Intro. June 8, 2009 Disc. April 13, 2010
Order MB990LL/A Model A1278 (EMC 2326*)
Family Mid-2009 13" ID MacBookPro5,5
RAM 2 GB VRAM 256 MB
Storage 160 GB HDD Optical 8X DL "SuperDrive"
Complete MacBook Pro "Core 2 Duo" 2.26 13" (SD/FW) Specs
por
Firstly, thank you for all your help.
I reset the PRAM with the original RAM, then replaced the 1 and tried to reset the PRAM however I got the three beeps...
por
Try the same thing with just one stick in each slot.
Reset the SMC:
Connect the power adapter to the Mac. On the MacBook / Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time. Release all keys and the power button at the same time – the little light on the MagSafe adapter may change colors briefly to indicate the SMC has reset.
por
So, resetting the SMC didnt work either :(
por
My smc wouldn't reset either
por
Exibir mais 1 comentário
The “data corruption” 3 beep pattern during the power-on self-test means that you (most likely) still have the wrong (or static-electricity damaged!) RAM.
Go to crucial.com and find out what the right RAM is.
Pontuação 2
1 comentário:
I have the exact RAM that is specified on the site you suggested...
por
Adicionar a sua resposta
kianicolaou será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 4,072
