Ir para o conteúdo principal
The Motorola Moto Z Force (XT1650) is an Android smartphone developed by Motorola. It also is known as the Moto Z Force for markets outside the US and has been available since July 2016.
How is LED selfie flash connected to digitizer?
I’m replacing the screen for my Moto Z. A couple of components need to be removed from the old screen/digitizer and connected to the new digitizer. One is the Selfie flash/flashlight LED. How is the power cable for the LED connected to the digitizer? There is no socket, etc. From the videos, it seems it’s stuck to the digitizer via adhesive. Is that correct?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello, its not conected with lcd or digitizer.... Heat the led And flex, take out And place on New lcd.... Its some metal connector on board an this touching directly to the led flex.... (Gold-plated
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks for your answer!
por
Adicionar a sua resposta
Tim Kirksey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 123
