Ir para o conteúdo principal
The EOS 6D was released in 2012 as Canon’s first consumer-level, full-frame DSLR. It comes pre-equipped with a 2.75”x2” LCD viewing screen, a GPS antenna and wifi connectivity.
My Canon 6D is not working properly
My Canon 6D is not working properly. I noticed my coloring is off, pink tones. I also have trouble shooting in low light with a 50mm 1.4. It is like not enough light is coming in even though I know there is. The images are blurry and and coloring is off. Every time I search this it says user error, I have manually set all my settings. My partner who does photography with me tried and she can shot fine with all the same settings and lens but my camera will not budge. Took it to repair shop, they said either communication error between the sensor and main board or main board is bad. Any thoughts?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If your partner's camera is a cannon, shoot with your lens in her camera, it'll give you an idea if the problem is lens or camera.
My 50mm doesn't auto focus. The mechanism gets jammed, does anyone have disassemble guide?
Esta resposta foi útil?
Pontuação 0
Related Parts and Tools
Adicionar a sua resposta
Jennifer Davenport será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 129
