Ir para o conteúdo principal
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
20 Perguntas Visualizar todos
My nintendo 2ds xl wont turn on?
It wont turn on. I have it plugged in. The orange charge light is on. But whether it is plugged in or not, when i push the power button, the blue light comes on for about five to ten seconds and then shuts off. No screen activity. And you can hear it shut off. It makes an audio click off type sound. Whats the diagnoses? I had it in my back pack. Too much pressure?
Esta é uma boa pergunta?
Pontuação 11
2 comentários
i as well like ass
por
love you kyle
por
Adicionar um comentário
4 respostas
Solução escolhida
Hey, Kyle. This can be caused by a couple different things. The first place to check is the battery. Remove the battery and inspect the three gold terminals for signs of corrosion. Then inspect the corresponding terminals on the board. clean these carefully and reinstall the battery.
If that doesn’t fix the problem, you’ll need to open your device further and check the two ribbon cables on the board (or any of the other 6). Based on what you said about the popping noise and the pressure of your backpack I would say this is most likely your problem. You need to make sure the two gold colored ribbon cables aren’t loose or damaged and that the pins on the board are also not damaged. Be gentle with the cables. If the cables are properly seated your screen is likely damaged and will need to be replaced. Let me know how it goes. Hope this helped and good luck!
Esta resposta foi útil?
Pontuação 3
1 comentário:
I had the same issue, and I'm aware of how the 2ds xl works. So my instinct was that I had a bad cable or display, but then I heard you mention the battery. When I took out the battery it looked just fine, so I thought it couldn't be the battery. I reinstalled the battery and then the 2ds xl turned on just fine.
So in short, it may be possible that you have the same issue that I had. Try taking out and plugging the battery into the 2ds xl
por
We have an issue where it knowingly got wet, but still charges, but won’t turn on. How do we fix it?
Pontuação 0
3 comentários:
My 2DS XL is brand new and now the screen won't turn on the origin light and red and blue lights come on but not the screen. What can I do?
por
I was having This same problem and then i just smacked the back of it like 15 times and it works now. https://c.tenor.com/p6od-lJcYHwAAAAd/the...
por
I had mine too for a bit I just did a battery change one of the speakers broke but when I try to turn it on not even a light just a quick flash on the screen and a popping noise
por
my console was working but touch was not working
so i change the touch and now it charge but not turn on ? ?
i checked all cables no sign of life
Pontuação 0
My 2ds XL won't turn on it shows a blue line at the bottom and it does a clicking sound after 5 sec and I charged it and it no work me sad 😭
Pontuação 0
1 comentário:
Tried removing the battery and putting it back in, still doesn't work, checked all the cables and nothing is broken
por
Adicionar a sua resposta
Kyle será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 60
Últimos 30 dias: 232
Duração total: 28,198
