Ir para o conteúdo principal
2010 iMac stand removal problems
hello,
i have a 2010 imac that needs some fixing but i cant get the stand off.
i have tried a palstic card but nothing has worked
Esta é uma boa pergunta?
Pontuação 1
2 comentários
What needs fixing? You don’t need to take the stand off unless it’s broken somehow.
por
what does it matter? you didn't answer the question >>> maybe to to mount it wise ass
por
Adicionar um comentário
1 resposta
Solução escolhida
Unlike the 27” model the 21.5” models stand is mounted from the inside! You’ll need to remove the logic board following this IFIXIT guide iMac Intel 21.5" EMC 2389 Logic Board Replacement unless it’s damaged somehow there is no reason to go this deep.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Moment Films será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 537
