Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
Battery Drain after updating to IOS 12
Hello!
I updated my IOS to IOS 12 and ever since I have updated it I’m facing a problem of battery drain issue and random shutdowns at around 70%. Battery Health is showing 94% and phone ran perfectly fine before this issue, is anyone else experiencing this problem?
Thanks,
Fahad
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Be aware that iOS 12 is a beta software and bugs are to be expected. This is probably a beta software problem because I know other people that have this problem too. It was fixed by downgrading their OS to iOS 11.
How to Downgrade to iOS 11
Esta resposta foi útil?
Pontuação 1
There are several methods you can try to improve battery life after iOS 12 update:
  1. Check the battery consumption of each app
  2. Turn down the brightness of the screen
  3. Turn on Battery Saving Mode
  4. Turn off Emails
  5. Turn off the Bluetooth if you do not use it
  6. Disable “Hey Siri”
  7. Set iOS to turn off the screen before there is no activity
Complete solution: How to Improve Battery Life of iPhone/iPad in iOS 12
Pontuação 0
Adicionar a sua resposta
Fahad Zareef Khan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 228
