Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Display Issues white screen
Hello,
I have the display problem from past few days i tried re installing IOS but still i have the same issue. Please advise
Mac book pro Retina late 2013 15” 2.03 Mhz
Esta é uma boa pergunta?
Pontuação 0
2 comentários
can you elaborate the issue you are facing
por
Amily,
I think its clear the display is bad the first image shows the internal screen with the colored bars. In the screen behind it you see the desktop. If you look carefully you can see in the second image the HDMI connection to the Samsung display. Also note the green haze on the 3rd & 4th image.
Unlike the older LVDS based systems where a loose or bad cable could be the cause. In the newer retina systems the signaling was changed to iDP (eDP) which sends s different kind signal similar to how analog to digital TV changed. iDP signaling is an all or nothing type of signal like how your digital TV works or if intermittent you get blocks like your digital TV.
The condition here is the decoder on the LCD panel which converts the iDP to the needed signaling for the LCD display its self has failed. Thats why Shark DJ needs a new display.
por
Adicionar um comentário
1 resposta
Solução escolhida
Sorry to tell you your display is damaged. Somehow your system got sat on or banged, damaging the LCD inside. You’ll need a new display assembly. Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 15" Retina Display Late 2013 Display Assembly Replacement and here’s the needed part: MacBook Pro 15" Retina (Late 2013-Mid 2014) Display Assembly
Looking at your Samsung display it too has a display issue! The horizontal line is what we call a TAB error which is where the metal oxide trace on the glass has broken on a few of the horizontal lines.
Imagem de Replace a display compatible with the model A1398 Late 2013 to Mid 2014 MacBook Pro 15" Retina laptop. Includes the 2880 x 1800 pixel 15.4" Retina LCD screen, display cover, bezel, FaceTime HD camera, clutch hinges, Wi-Fi antenna, camera, and display data cables.
Produto
$319.99
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you !!
por
Adicionar a sua resposta
shark dj será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 380
