Ir para o conteúdo principal
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
How to replace knock sensor?
I have a 2006 F-150 with the 5.4L Triton engine. The engine code said there was a bad knock sensor at an auto store. I now know there is two knock sensors if I’m not mistaken. I’m wondering how to locate and change both of them? I will determine which one is bad today but might as well replace both.
I’m really struggling with finding a good resource online to help me. Normally these things are on YouTube but for some reason this replacement isn’t for this type of engine!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
https://www.justanswer.com/ford/4bokm-20...
Update (07/12/2018)
I have the same issue, this link has the pdf instructions, think I'm going to tackle on my own, however seems more involved than I originally thought...
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you very much! I agree it’s a lot of work but !&&* of a lot cheaper than a shop!
por
Adicionar a sua resposta
Guner Kaczmarek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 27
Ao todo: 13,732
