Ir para o conteúdo principal
The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
20 Perguntas Visualizar todos
Why is my charging port stuck inside the speaker?
So I dropped my speaker the other day, and the charging section of the speaker (the micro usb and the aux port) fell back into the speaker. I can not see a way to disassemble the speaker and I would really appreciate some help. Thank you in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @dock231,
If your JBL Charge 3 speaker’s ports are no longer working, see the JBL Charge 3 Ports Don’t Work problem page for possible problems and solutions.
Try referring to this video for an idea of a teardown.
https://www.youtube.com/watch?v=DLOKYJLJ...
When you reached the USB port, inspect the board for any damages.
I would suggest you not to bend back the USB port to the original position, as it may rip away the electronics traces.
If it is badly bent, I would suggest you get a USB port replacement, places like eBay, aliexpress...
https://www.ebay.co.uk/itm/Genuine-Micro...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Matt Dockendorf será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 2,458
