Ir para o conteúdo principal
Released in October, 2015. Identified by Model Number GL752VW-DH74.
Why my keyboard would not light up?
Hi,
I've following problem. After an windows 10 update my keyboard backlight stopped working, i've tried to reinstall ATK package and nothing special happened. It would not light even when i start the laptop, i pressed FN+F4/3 many times, i saw it tells me "Brightness up"; "Brightness down" and nothing happens. All FN + button working.
Esta é uma boa pergunta?
Pontuação 5
1 comentário:
HI,I also have a problem with the batterie not charging anymore ,it sais 0%,disponible,connected,not in charge. I saw a lot's of people with this problem on the asus752
por
Adicionar um comentário
4 respostas
win10 ATK driver pack
Esta resposta foi útil?
Pontuação 0
1 comentário:
How to install?
por
Related Parts and Tools
Shop all
Hi! I had this problem too for a long time. Mine did not occur after a windows 10 update. I updated my gpu driver and then it stopped working. Here is the soultion:
Go over here and download the tool https://www.guru3d.com/files-details/dis...
Then uninstall the nvidia driver using the tool (you can check tutorials online if you dont know how)
Afterwards go to nvidias official site: https://www.nvidia.com/Download/driverRe... and download this latest driver
After that the prolem is solved! It seems that the nvidia driver interfeared with the backlight.
Pontuação 0
Download the correct ATK Package for your Machine/OS, from the ASUS Download site, The 8.1 package works for win 7. First uninstall the one{s} you have installed, then install the new one.
Pontuação 0
happened to me when i upgraded from 8.1 to 10, all i did was uninstall the old drivers completely and then reinstall the new ones and during installation of he drivers the keyboard backlight started to work again, good luck
Pontuação 0
Adicionar a sua resposta
Теодор Христов será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 29
Ao todo: 9,663
