Ir para o conteúdo principal
Third iteration of the India hand pump
differences between a mark II and a Mark III Hand pump.
Please how can I identify a Mark II and a M ark III pump in the field . What are there differences and similarities?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Major difference between India Mark- II & IndiaMark- III 65 is given below
India Mark- II 32mm Hand Pump
1. Water tank with 1 1/4" socket,
2. 1 1/4" riser is used with IM II hand pump
3. IM II reducer cap is fixed with cylinder to suit with 1 1/4" riser pipe
India Mark- III 65 hand pump
1. Water tank with 2 1/2" socket
2. 2 1/2" riser is used with IM II hand pump
3. IM III open top cap is fixed with cylinder to suit with 2 1/2" riser pipe
With best regards………………….
Umesh Kumar
Ajay Industrial Corporation Ltd.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
okonkwogillkenny será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 2,124
