Ir para o conteúdo principal
Is the GPS and WiFi antenna the same
some one told me their GPS does not work, now call me silly but isnt this the same as wifi?, and if so when i tested the wifi it worked perfectly
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Well no, the WiFi and GPS antenna are different.
YES the location tracking on an iPhone usually works using WiFi hotspots (accessing them to track your location).
But no it's a different component, if the GPS isn't working it's most likely something wrong with the location services, or the IC of the logicboard
(Murata 339S0228 Wi-Fi Module is on one side and Qualcomm QFE1100 Envelope Tracking IC, RF Micro Devices RF5159 Antenna Switch Module and Skyworks 77356-8 Mid Band PAD on other side of logicboard, see iPhone 6 Teardown for more info, btw in case you need to replace, see iPhone 6)
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hi,
My RF5159 Antenna Switch Module Ic Chip, has fell off from my motherboard, and I can't find not tutorial whatsoever on how to reinstall it, do someone know about any link on how to do this? Thanks.
por
Related Parts and Tools
Shop all
from my knowledge, it is the BT/WiFi that run off the same antenna.
GPS uses Wifi Signals to help Tune the signal into something more percise, but doesnt base its function out of the same chipset. which means if it is just strength issues, the antenna would be at fault, but if there is absolutely zero function, you are likely looking at a board level failure.
try replacing this compoenent, and if not, then board work may be needed.
iPhone 6 Logic Board Antenna Flex Cable
Imagem de Replace the antenna flex cable that has four connectors to the logic board compatible with the iPhone 6 model A1549, A1586, A1589 smartphone.
Produto
$9.99
Pontuação 2
1 comentário:
What can be confusing is your phone uses two additional methods of triangulation: Celluar and WiF besides GPS/GLONASS satellites. Here's a bit more: GPS Navigation
The antennas are within the case its self (top & bottom isolated surfaces). The flex cable here is a signal guidefrom the logic to the cases connection point.
More likely, the GPS logic within the logic board has been damaged.
por
Adicionar a sua resposta
Tracey Homeward será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 5,783
