Ir para o conteúdo principal
The DZ09 is a Chinese smart watch with basic features and the ability to make calls. These can be as cheap as $10! (Yes, you read that correctly!)
How do I fix the Charging Error?
My smart watch charges for about a minute then a message pops up saying "charging error", then the watch siezes to charge . How do I go about repairing that ?
Esta é uma boa pergunta?
Pontuação 7
5 comentários
Not open my smartwatch place open my smartwatch dz09
por
When my smart watch on it says in a few seconds later “Charging Error” .But when i shutdown it it takes a lot of time but not a charging error DIALOGE
por
Shut on hni ho rha automatic shutdown
por
My dz09 smart watch ka charging pin demeg
por
My watch not switch on not charge
=== Update (10/10/23) ===
My dz09 smart watch not on not charge
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Check the charging port to see if it has anything in it. It not the cost of repair is more than this watch is worth. I would just get anotherone.
Esta resposta foi útil?
Pontuação 2
1 comentário:
it looks like a common problem just keep unplugging and re plugging it in seems to work on mine ,also after watching a video on you tube it may be play in the battery so just pop a piece of cotton wool on top of the battery and put the back back on may solve the problem .
por
Adicionar a sua resposta
Joel Will será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 6,131
