Ir para o conteúdo principal
The Nikon D7000 is a 16.2 megapixel DSLR launched in 2010.
Why is my memory full
My Nikon D7000 diplays full when I try to take pictures.I had been fiddling with the buttons and I think I accidently pressed something . I have a 8gb memory card and only 200 pictures in my camera . The memory card had been working well up until now .HELP
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Your memory card is probably faulty.Try using another one
Esta resposta foi útil?
Pontuação 0
Most times its the SD Card get yourself several good high Quality #10 32 GB SD Like Sandisk. I’ve been using the same cards since I got the camera back in 2010 I have shot over 25,000 photos I recently replace my SD card with 64 GB (that the largest you can use in the Camera). also you can set the Top Card just to store RAW and the bottom one to Store Jpgs.
Pontuação 0
Adicionar a sua resposta
Albert Einstein será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 251
