My Chromebook is always low on space
I think there is a partition in my drive and I can't find my OS backup, what should I do?
Esta é uma boa pergunta?
Obtenha acesso rápido a guias, peças e respostas para seus dispositivos
You can create a recovery USB drive by using the method on the link below or you could power wash the Chrome device, which usually does the same thing.
Im not sure how much hard drive space your Chromebook came with, but it's usually around 20 to 32gb.
Esta resposta foi útil?
Yeah, I'll try that, I've probably power washed it a dozen times but nothing works so, thanks.
Try to use the recovery method then. Hopefully that'll clear your space up.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 89
