Ir para o conteúdo principal
The third-generation Nissan Sentra was released in 1990 and produced through 1995. From August 1992 production, the B13 received a facelift for the 1993 model year.
2 Perguntas Visualizar todos
wet and black spark plugs
l started noticing that the car was now lacking power, and when l checked the plugs. l realized they were black and wet. what can be the causes and how can l differentiate that the wet substance is petrol or oil?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Fouling plugs is a pretty common problem for a motor that has bad compression. Easiest way to figure out if it's oil or petrol is to pull the plugs out and wait about 3 minutes then touch them. If it's oil it will still be wet, if it's petrol it will have evaporated
Esta resposta foi útil?
Pontuação 5
Adicionar a sua resposta
xolani será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 4,114
