Ir para o conteúdo principal
Nissan introduced the sixth generation Sentra at the 2006 North American International Auto Show in January.
11 Perguntas Visualizar todos
Stalling after tune up and changing mass air flow sensor
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Did you replace the MAF with a Nissan part, or an aftermarket one?
por
Adicionar um comentário
1 resposta
Did you scan your car prior to installing the MAF to make sure that was the actual problem? Or is it was a mechanic did you see the print out? Then after installing the part, did you clear the codes, test drive and check to see if new or same codes came back?
MAF sensors are very fragile, and can be easily damaged during install by being rougher than necessary.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Marcus Napoleoni será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 445
