Ir para o conteúdo principal
Guias de reparo e suporte para notebooks da Dell.
20 Perguntas Visualizar todos
Wi-Fi and Bluetooth switch doesn't remain ON.
My laptop immediately turns off the Wi-Fi as soon as I turn it on.
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
Hi @denisemason ,
What is the make and model number of your laptop?
What OS is installed?
Have you checked in Device Manager > Network Adapters to view the status of the WiFi adapter?
por
Dell Inspirion 17R
Drivers are fine. Windows 10.
Wireless adapter working properly.
The laptop worked fine on Friday, then on Monday , I couldn't turn the Wi-Fi on. The button goes back to OFF. I noticed the Bluetooth is doing the same thing.
I removed the network then reinstalled, rebooted and nothing. I'm about to scream.
por
Adicionar um comentário
1 resposta
Are the Wi-Fi drivers installed correctly? If not, reinstall them and see if thats the problem.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks but the drivers are fine.
por
It says Wi-Fi is off because PC is in airplane mode but when I go to airplane mode, the selections are darkened, I cannot change it.
por
Adicionar a sua resposta
Denise Mason será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 51
