Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Will Drain but Won't Spin
I have a Kenmore Washer model number 110.21302010. It will get to the final Drain/Spin part of the cycle and will drain and drain and drain (I can hear the motor trying to suck out all of the water) but it won't ever spin. Clothes are wet. I've tried going to the Rinse/Spin cycle as well as the Drain/Spin cycle and it never gets to spinning.
I recently had the same problem but the washer was able to spin if I used the Rinse/Spin or Drain/Spin cycles. I ended up replacing the Actuator and it worked for about a week or so and I'm now having the same problem but it won't spin at all (it will agitate during Wash and Rinse cycles).
Anyone have any ideas?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I have this problem as well. There is no telltale sign that the washer is malfunctioning, but all it does is drain the water - no spin action at all.
I find that if I manually turn the tub about 90 degrees and restart the spin cycle, it will then work properly. Any ideas on what the solution might be?
por
Adicionar um comentário
2 respostas
Timothy Gunter start by checking the lid switch with a multimeter. A failed lid switch could prevent your washer from spinning. #14 in the illustration. This video will show you how to get to it.
Esta resposta foi útil?
Pontuação 0
Have you tried using a shop vac to suck the water from the pump drain hose? Some times there can be a build up within the pump housing and/or drain hose that can restrict the water from being ejected properly. Also the home drain lines can get clogged at the P-trap with sediment from years of build up as well. Try removing the machine’s drain hose and sucking that out as well. You may be surprised at what come out of the shop vac.
Pontuação 0
Adicionar a sua resposta
Timothy Gunter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 2,423
