Ir para o conteúdo principal
The Acer Aspire Switch 10 SW5-011-18R3 is a 2-in-1 Tablet with docking keyboard running Windows OS. It was originally released May 2014.
13 Perguntas Visualizar todos
Recovering data with broken system
Windows 8.1 won't boot on this device. I have some important files to recover from it. Bootable usb with linux doesn't help. Is there a way to get them back?
Esta é uma boa pergunta?
Pontuação 0
6 comentários
Do you have a working desktop PC? So you could test the disk.
por
i have but im not sure if it has internal hdd
por
How did it break? did you drop it? spill something on it?
por
i installed updates and the system crashed
por
Problem fixed: i booted the windows 8.1 usb drive, then launched cmd. Using it I managed to move all the files to the usb. However switching between the drives doesn't work without "cd /d c:\".
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Pergunta mais útil
You can try using an external USB adapter for the drive and then connect it to a working computer to try to copy your data.
Esta resposta foi útil?
Pontuação 1
2 comentários:
does it have hdd though?
por
HDD or SSD? both should work fine with a hard drive docking station. You can find them on amazon I'm sure, or just open up your desktop and connect with sata.
por
Adicionar a sua resposta
Tomasz Kowalski será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Ao todo: 429
