Ir para o conteúdo principal
A 17" touch screen notebook designed for every day use.
Will not Connect to Network
As of a couple of days ago, my HP will only connect to WiFi in my home but not when the Ethernet cord is plugged in. I make sure the WiFi is off when trying to connect hardwired. There aren't any networks found. I have tried a system restore, removing the battery for 30 minutes but this did not resolve the issue.
I use my laptop for work and I cannot be connected wireless. I need to be hardwired. Does anyone know why my HP won't connect when hard-wired?
By the way, there is no damage to the Ethernet cord or the port.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Do you have another Ethernet device which is working with the same port & cable? Does the port have a link light? If it does is it blinking?
I would still try a different port on the hub and cable if you don't have a second device to verify. Sometimes the damage is not visible.
You may need to go into the Windows network settings to see if the Ethernet device drivers are loading
Esta resposta foi útil?
Pontuação 1
1 comentário:
Yes I also tried a different Ethernet cord and yes there is a light. I don't have the Ethernet cord in now to see if the light was blinking or not. I will follow up about this. The drivers showed as well.
por
Adicionar a sua resposta
MizzNeda será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 107
