Ir para o conteúdo principal
Repair guides and support for tablets made by Hipstreet. These tablets run on the Android OS.
Enable an SD Card
I want to enable an SD card on my Hipstreet Pulse but cannot seem to find a way for my downloads to go to the card.
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Same problem. I can change the default storage to the SD card which has been formatted as internal memory but downloaded apps still go to the main memory. When I try to move an app to the SD card I get the "insufficient memory" error even though the SD card is almost empty.
por
Adicionar um comentário
1 resposta
Go into device settings and go to storage …
Put the SD card into the slot on the side and it should come up with a bar in the middle of the screen
Click change save destination and vuala it should work
I did this on my tablet
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
lady_hawk_ca será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 376
