Ir para o conteúdo principal
6.1 megapixels, ISO 200-1600, DX format, 1.5x field of view crop
Mode dial not functioning
The mode dial (pos 10 in pict.manual) appears not to function, after selecting a position, the camera remains in automatic mode, dial moves in a sticky way.
any solution?
Thanks
Paul
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
By using contact cleaner spray to the dials and buttons, after which I applied compressed air in order to dry the areas, problem was solved. Had to do it a couple of times
Esta resposta foi útil?
Pontuação 1
1 comentário:
Makes a lot of sense what you tried, although I would have used rubbing alcohol and no compressed air. Good job, you figured it out yourself.
por
Adicionar a sua resposta
Paul Willems será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 1,151
