Ir para o conteúdo principal
How do I erase the bios password
I have a lenovo thinkpad yoga 11e. I forgot the bios password. I can't login to my computer. Is there a backdoor bios password? If not, then does removing the CMOS battery work? If it does, then how would I do it?
Esta é uma boa pergunta?
Pontuação 5
3 comentários
Good Morning
I have a lenovo thinkpad t560 and wanted to reset the bios pass I can use this method
por
Did this work?
The computer needs to be on?/with battery?
por
i want bios password remove to x1 yoga laptop
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
To reset the BIOS password you need to remove the coin-cell battery and short out its contact points. This should reset the password.
We don't have a guide on your specific model, but I came across this user manual that explains the procedure of replacing the battery. Scroll to page 108. Good luck.
Esta resposta foi útil?
Pontuação 6
10 comentários:
Thank you so much!!!!! This is exactly what I need!!!!!!
por
how do i short out its contact points
por
@The Rebel: You take a metal object and touch both contact points of the battery slot.
por
What does the coin cell battery look like is it a blue round thing
por
Exibir mais 5 comentários
Adicionar a sua resposta
Zach Asay será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 41
Ao todo: 43,661
