Ir para o conteúdo principal
The HP Pavilion dv2000 Notebook PC is an entertainment based PC produced in 2007.
Is my screen broken or is it something else?
I have a 2009 HP Pavilion dv2000 laptop.
Its in pretty bad shape. Its hinge is broken, it makes !&&* lot of noise, graphics card is trash.
But, atleast it could switch on for basic stuff. Now its screen is broken as well. Its divided into 6 parts, consisting of colorful rectangles.
Please guide if I replace the screen, will it start working as it used to or there is some major fault?
I plan to replace it myself, is it doable?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It looks like you have a few issues here. The screen is broken (the black bar). You could also have a GPU issue here as well. How does the image look on an external display? If you still have the colorful screen the GPU logic has issues. If its clean then the internal connection to the display is suspect.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I haven't been able to plug it to an external display. Will do it and check.
por
Adicionar a sua resposta
Hanush Anand será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 158
