Ir para o conteúdo principal
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
20 Perguntas Visualizar todos
Computer shuts off very frequently.
My computer turns off itself very often. Some times stays on only for seconds .
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
It is probably an overly sensitive heat sensor. You should contact Dell tech support and see if your computer is in warranty. The warranty is one year unless you buy an extended warranty. The problem is mostly likely to be the mother board.
Esta resposta foi útil?
Pontuação 0
I had this problem too. In service cleaned it, changed the silicon paste. And it work nice.
Pontuação 0
Adicionar a sua resposta
Juan Carlos Aragon Espinosa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 11
Duração total: 75
