Ir para o conteúdo principal
Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
17 Perguntas Visualizar todos
Why do I not have any acceleration
I have a 2005 Nissan Murano se I've replaced the alternator, the accelerator pedal sensor, the throttle control body, and the thermostat as the codes was throwing up on the obdm. I have tried clearing it out and the codes go away for a minute but come right back. I also did the relearn on it. Help me please...codes are 1122...etc actuator malfunction.....1126 thermostat stuck open...but I replaced the thermostat. I can't get the codes cleared out for some reason
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
it might be the about to alternator burn out
Esta resposta foi útil?
Pontuação 1
I just started expiriencing the same issue with my nissan ive replaced the throttle body but cant get the code to clear or even accelerate but i'm working on it soon as i get it fixed i'll let you know(code 1122)
Pontuação 0
Adicionar a sua resposta
Jennifer Logan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 1,354
