Ir para o conteúdo principal
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
How to fix Hyperflashing LED Turn Signals?
I recently installed LED rear turn signal bulbs onto my 05 Grand Caravan SXT, I want to know a good way to stop the hyperflashing that happens.
Is replacing the fuse with a higher amp my best bet when it comes to this? I don't want to spend too much on this. If this is my best bet what is the fuse/ relay called?
Thank you.
Lights I used
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
No, you need to install a resistor in parallel with the led globe, as the current draw if the Led is not enought to operate the flasher relais properly.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Scott será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 567
