Ir para o conteúdo principal
Support and repair information for Beats Solo3 headphones.
Fixing no sound in one speaker on blueooth
I am having issues issues with the right side of my Beats solo3 wireless headphones. On bluetooth no audio comes out from the right side and the right side will only work if i jiggle the left side. Both sides work fine when using the aux cable for wired setup. What could be the issue?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
5 respostas
Pergunta mais útil
Plug in your auxiliary cord to your headphones to device, play some music, and if it works like that than take the auxiliary cord back out, turn on blutooth and both will start working again.
Esta resposta foi útil?
Pontuação 2
8 comentários:
I did it and it didn’t work. Twice. Help plz!!!!
por
It didn,t work for me either
por
Didn't work for me either
por
Didn’t work for me either.
por
I know this is old, but i just tried this and it worked
por
Exibir mais 3 comentários
I have the same problem too
Pontuação 2
If anyone is still having this problem I was able to fix my Beats Solo 3 Wireless issue with no sound on one speaker on bluetooth after I followed the instructions on this video: https://www.youtube.com/watch?v=kypDTpO_...
Hope this helps.
Pontuação 0
1 comentário:
This doesn’t help at all.
por
It could be a loose or damaged connection, would have to disassemble and inspect to determine the correct issue.
First try a reset etc.
Pontuação 0
Bruh I don't know what to tell
Pontuação 0
1 comentário:
Yeah you might need new ones
por
Adicionar a sua resposta
MrSnowyOwl será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 21
Ao todo: 46,248
