Ir para o conteúdo principal
Quit working wont turn on
Conair bonnet hair dryer only 3 months old quit working
Esta é uma boa pergunta?
Pontuação 1
1 comentário
My Conair hair dryer stopped working, should I send it back to the company
por
Adicionar um comentário
3 respostas
Solução escolhida
Suzy Cory, Try another known working outlet. If no go, more then likely has a one year warranty on hair dryer and you may want to consider contacting the manufacturer for repair/replacement/refund. If not you could disassemble the hair dryer and test/check all connections, cord/plug, switch, if fused check, with a DVOM to see if faulty. Below is a guide to disassemble various models that may help. If not wanting to work on the dryer yourself perhaps have a good local small electronics shop have a look, diagnose and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Hair Dryer
Esta resposta foi útil?
Pontuação 2
2 comentários:
Looks like we were answering this at the same time.
por
mayer, yes, been a while since it had happen :-)
por
Related Parts and Tools
Pergunta mais útil
It is covered under warranty. First try returning it to place of purchase.
That failing, register it here, then request a warranty repair:
https://www.conair.com/co/101e94/product...
Pontuação 2
If it experienced a reduction of airflow, you might have tripped the safety fuse on the heating element.
Pontuação 0
Adicionar a sua resposta
Suzy Cory será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 61
Ao todo: 11,531
