Ir para o conteúdo principal
The BLU Life XL can be identified by its model number: L050U. This smartphone was released January 2016, has a octa/quad core processor, Wi-Fi capability and a 13 mega-pixel rear facing camera.
data access suddenly stopped working
I actually have a Blue Life XL. About a month ago, data stopped working and I assumed it was a provider issue. Two calls to them led to the conclusion that it's NOT them. All the rest of the family continue on with no data issue on their iPhones. T-Mobile offered little guidance as it is a non-network phone.
Was working fine for several months until non-wifi data suddenly stopped working and I don't know where to start in trying to fix it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
First check the APNs:
https://support.t-mobile.com/docs/DOC-20...
If this is already configured, try a factory reset and configure the APNs again.
NOTE: BACK UP YOUR DATA FIRST!
I would also then try one of the SIM cards that you know works.
If this has failed, there is something wrong with the phone and you should look into a repair or replacement.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Great job to 4k rep! 6k to go.
por
This was a great help. I checked the settings and they seemed correct, so I went ahead and restored the factory settings and I'm good to go. I feel embarrassed that hadn't tried that already. THANK YOU!
Pontuação 0
Adicionar a sua resposta
Neil Grepke será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 163
