Ir para o conteúdo principal
The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
20 Perguntas Visualizar todos
Where can I get another Wifi antenna?
My Toshiba Chromebook 2 had to get a screen replacement and subsequently afterwards the wifi antenna wire broke. Is there a replacement part? and if not what is the best method for repair?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Stone Dresser, had no luck finding just antenna, see link below, may work for you. Replacement cover with antenna. If not ignore. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://skyline-eng.com/toshiba-chromeboo...
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Stone Dresser será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 320
